O2 Housing Question
Talon2z
73
Feb 28, 2004
Richmond, Virginia
I just received the Joe P O2 housing today and I noticed three pin-sized holes in the welds. Is this enough to cause a problem? Should I send the piece back? What do you guys think?
Are they holes are just inconsistencies in the surface finish.
If it leaks when you try to pressurize it you will possibly have problems. They should replace it.
Additionally you may have a weakened weld in either case and it could crack if it looks serious. Give them a call they may be more than happy to fix/replace it.
