Notch Internal-eliminate Creep-experience
sweet97
2,386
18
Mar 6, 2004
auburn, New York
OK. I amabout to install an AGP 50 trim internaly gated.
I don't know where they measure the 38mm but the hole is MUCH less than 38mm. A quarter fits through with some to spare so 28mm is more like it. Back to topic. Does notching between the gate ad the turbine's exit as some 50 trims come will this eliminate creep? I have heard "disrupted exhaust flow". I doubt I nor the car will feel this disrupted flow, I just don't want to go cutting an expensive piece if it's not needed. Will an internal 50 trim NOT CREEP?? Thanks, Mark
my 16g what ported and the gate ported put the car back together still creeped so i notched the gate the the turbine and it stoped all of the creep except very high rpm like 5500 it creeps very little
I just pulled my turbine and am going to notch it right now. Thanks, I cannot afford creep because I am using 550cc inj's for a few weeks until the car goes into storage in my insulated and soon to be heated garage. Upstate winters can be boring when you are disabled. now I can get some physical therapy, mental therapy also! Mark
