Migsubishi
- 59
- 0
- Oct 11, 2008
Tampa,
Florida
What's up people, My name is Miguel, should be obvious by screen name
I used to have a membership on this site back in the day but haven't been on in yrs. Needless to say I forgot my login and couldn't retreive it, so here I am again starting fresh.
I might be new to the site this time around but definitely not new to dsms or evos, I do alot of my own work and have worked for several shops in the area.
I'm on evom,dsmtalk, and various other boards where I post more often, so now I'm trying to divert more of my attention to this site as you guys seem to be very knowledgeable.
My current toy is a 99 Honda civic with a fully built 99 7-bolt 2.3l high compression stroker
Wiseco 1400hd high comp pistons
Crower super billet rods
Eagle crank
ams balance shaft kit
o-ringed block all balanced
mild ported head, deshrouded valves and cleaned bowles
std ss nitrated ss valves
FP beehive springs
Jun 272 cams
crower gears
custom JMF intake mani
etc etc etc
Car runs on two fuel systems
primary is 93 octane with evo 550cc injectors
uses one walbro 255lph
secondary is E98 with Moran racing 2500cc injectors
uses dual bosch 044's
There is so much more but don't want to bore you guys//
Oh it's AWD and currently converted to big stall auto with direct port.
Here is a vid of it when 5speed running 24psi with issues but still pulls through... The car wasn't making 500hp that night due to breaking up badly and having to short shift. You can here it on the first run if you listen closely.
500+whp awd 4g63 powered Civic -vs- Evolution IX MR on Vimeo
Eagle crank
FP beehive springs
Jun 272 cams
crower gears
etc etc etc
