420A Need some exhaust advice
drosales99
Feb 14, 2011
moreno valley, California
Ok so I found some headers for my 420a 99 eclipse but I have about an inch of a gap from the pipe to my cat. Would it be ok to fab a spacer instead of having to go thru the hassle of welding n extension ?!? Also I just picked up some rear stabilizer bars but I don't know where the lower 1 goes!!!!:ohdamn:
Spacer should be fine though I'd think it would be cheaper/easier to just weld pipe. You could also look for pipe that has the same inner diameter as your exhausts outter diameter and use it to bridge the gap. You'd have to get some U clamps to tighten down both ends, but it's another option to consider.
