Need Opinions
nano:
I'm front wheel drive as well, I probably won't ever get 60' as good as you...although I could get better than what I have...I am doing it correctly just not as strongly to avoid spinning. I will admit I need some practice at the track.
larryd:
Thanks, that what I thought and was hoping, I think the DSMLink is the best all round for the 2G's
Hey 97TalonTsi- yup, that is correct, DSM LInk talks to your ECU through the laptop, you load the data into the ECU and unplug. I know your worry, my car is my daily also- but if for whatever reason you should reset the ECU, all it will "forget" will be the timing and fuel maps...you can still drive home, no sweat (although you will be slower! )
Then again, you will have no speed limiter, fuel cut, and endless tuning parameters saved when you go to the dyno...etc.
Oh, and as far as your 60'in a FWD...get some slicks...you will not believe the difference!
