Need help with my 20G guys!!!
hippy
322
Jan 18, 2004
chtown,
It goin on a 1g laser fwd!! This is a list of what i have and i want a hit a 11.99 by the end of teh summer ok!! Tell me what else if i need more stuff thansk!! Just looking for opinons!!
Jdm motor with Web 546/547 cams
2.3" down pipe no cat 3"from flex with 3" muffler
hks evc5
taylor 10.4 wires
walbro 255 pump
hks ssbov
brand new 24" by 12" by 3.5" fmic
2.5" hard intercooler piping
egt/boost/a/f guages
afc
laptop with logging software
act 2600
rc 720cc injectors
This is everthing i have gotten over the winter!! Im goin to buy a 20g next thinking Hahn!! Anything else i need u guys can think of?? I know for sure a lsd LOL, and maby a afpr!!! Wha telse would be good?? I should be able to hit a high 11 by the end of the summer dont u guys think?? Or really low 12's!!
Ok ya i may just buy a lsd insert for time being!!! And slicks i had a ####ing set and sold them i will have to pick up another set i guess!!!! Tahnsk alot!!:thumb:
Ya to be quite honest i think that is the one im goin to buy!!!
Use a 1G CBV with vent mod over the SSQV. You dont have any kind of fuel control listed. 720s are pretty big. You may want to go with 650s or 660s, with an SAFC or perhaps MAFT. I wouldnt worry about the Hahn 20G. They are overpriced. Infact, I would steer clear of 20Gs altogether. You can get a 50trim hybrid for about the same, or cheaper. With a stg 2 turbine wheel it will spool incredibly fast. I would use the bigger T31 76trim(stg 3) however.
Stay away from the Web cams. Go either HKS ( proven ) or Comp Cams ( just released, but look good on paper ). SBR has both at good prices.
If that's HKS's boost controller, a good MBC would work just as well. Even a Profec B II works as well and is pretty cheap.
taylor 10.4 wires
The NGK blue wires are fine.
A/F gauge is a blinking light. Save it for Christmas. :p
A good pocketlogger and Palm IIIe would work just as well, unless you have the laptop already ( lucky :) ).
rc 720cc injectors
For fuel control, stick with the S-AFC, but add a DSMchip.
www.dsmchips.com
Its the best way to go for anyone on a budget and not looking for standalone. You will need the AFC to make adjustments to your car and boost level though, so it does not replace it.
You can get a nice lsd alternative here
Inserts are a big no no. Slicks + insert = everyone laughing at you when you blow your differential at the line. Go Kaaz, here's why:
http://www.magnusmotorsports.com/kaazvstorsen.asp
