Need help with calibrating MAFT with DSMlink
DSMboostin15
502
6
Sep 1, 2005
Dubuque, Iowa
Like the title states, I'm finally calibrating my MAFT with DSMlink. I've already adjusted the 50Hz slider to +8%, but when it comes to the 150Hz slider, the STFT and LTFT-Lo still read the same value (0.0%) as it did when I adjusted the 50Hz slider. And a side note here, for idle tuning, should I go by the WB (LC-1) or the A/F ratio in Link. I've also posted a copy of the log file if it helps. Thanks.
Ryan
You need to log ltft mid for the 150hz slider. It is going to take some time for the values to actually change when it comes to the fuel trims. Always go by the wideband display first then what dsmlink says the wideband if there is a problem with the display. If you have a wideband (which obviously you do) you don't want to look at the air/fuel estimate in dsmlink because it is just that, an estimate.
Hit F4. Click once on boostest. Then click on props. Input your altitude and save it to the car.
I thought you were not supposed to touch the MAFT settings at all just leave them at zero and adjust link like normal.
That is correct. He is almost ready to start calibrating the gm maf through dsmlink. Your not actually changing the maf-t settings. You are making sure the ecu is seeing the right amount of airflow from the maf. Right now he is doing idle and cruise tuning.
Ok so he is not calibrating the MAFT just adjusting the injectors to his setup.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
