Need help, i think i bought the wrong turbo!!!
if your concerned about any lag whatsoever at the start that you might get, just invest in a stutter box, spool that bish up off the line.
EvilAWD said:
looking back at the responses you guys have given me. it seems like everyone has bigger injectors. whats a good injector size for my 60 trim? do 780cc seem pretty suitable for maybe 22 pounds of boost? im pretty curious i have 720 that i havent installed yet although im going to go with a stand alone so does that help out the situation?
You keep refering to a standalone??? Your car is probly nowhere near needing a standalone let alone the tuning timing and cost it will take. I am running a T66 on my 2g and it is still on DSMLINK no problem. I am pushing 32psi. I had a 60-1 and yes its a big turbo but exactly like it was stated before.....if you have never run a bigger turbo :notgood: about lag. Only people that have run bigger turbo's will realize that the amount of extra PULL it gives you once it spools will more then compensate.
P.S- I get ~30psi@ 6000RPMS
Matthew
