Need help finding out my Paint Code
Dave4g63
Supporting VIP
203
Nov 28, 2009
Newport, New Hampshire
I've got a 95 Eclipse gst that needs a new front bumper so im just going to order one pre-painted but i can't find my paint code anywhere on the car. the sticker on the fire wall is so faded its pretty much blank. when i bought the car it had a fresh paint job so im not sure if its even the stock green. the color tends to shift a bit from green to blue depending on the time of the day.im not sure if a stock green has that property.
thanks
You need to find out if it's an oem color, or very least if they repainted it with an oem color.
If it's not, I would take it to a paint shop and have them compare some paint samples so you can find the paint code.
Do you have a picture of your car?
yes i do i tried posting the best one i had but it didn't work , there are several of my car on here tho.
<img src="http://www.dsmtuners.com/gallery/files/1/1/3/5/6/6/av.jpg" alt="95 Gst" />
It's really tough to tell by that picture.
Does the engine bay, door jambs, and trunk match the exterior color?
I believe I've seen that green on a couple 2g's before, I'll have to do some searching though to be sure.
yeah the paint in those areas matches the paint on the car maybe these images will be a bit better
  • Wanted 6 bolt NT water pipe
    • chrisman287
