Need help finding CAS wire....?!? please help..!!
MarkyGsX
80
Aug 27, 2004
Carson, California
hey guys...im installing my maft set up and i couldn't find the cas wire....i know it is suppose to be the harness on top of the crankshaft position sensor like it shows in the haynes manual but my 90 gsx does not have a harness coming out of my cranshaft position sensor anywhere...? am i looking at the right place.....? is there anywhere else i can tap a rpm signal...? any and all advice appreciated....
The CAS for your car has some wires coming out of it that lead to a plug on the firewall (close to middle). This is the plug shown in the manual when they test the CAS. It is not located on the sensor itself. You will see if you carefully follow the wires coming out. Be careful with that manual because it contains MANY errors... :toobad: Good luck with your ride! :thumb:
