MY FIRST LOG please look
2gntrbo
107
Aug 8, 2006
kalamazoo, Michigan
my mods are in my profile. and i only had my boost set at 10 and spiked to 15. after i logged, turned around to head back to my house and then when ever the turbo would make boost i would hear a loud squealing noise. im stumped. well here it is and yes i am going to make a boost leak tester in about 20 mins
TIME TIMA RPM KNCK
04/19/2007 11:35:15 24° 2125 0
04/19/2007 11:35:15 26° 2125 0
04/19/2007 11:35:15 31° 2125 0
04/19/2007 11:35:15 34° 2125 0
04/19/2007 11:35:15 36° 2094 0
04/19/2007 11:35:15 37° 2094 0
04/19/2007 11:35:16 37° 2063 0
04/19/2007 11:35:16 37° 2031 0
04/19/2007 11:35:16 37° 1938 0
04/19/2007 11:35:16 34° 1844 0
04/19/2007 11:35:16 28° 2094 0
04/19/2007 11:35:16 24° 3125 0
04/19/2007 11:35:16 24° 2938 0
04/19/2007 11:35:16 20° 2875 8
04/19/2007 11:35:16 20° 2844 8
04/19/2007 11:35:16 18° 2938 8
04/19/2007 11:35:17 17° 2938 7
04/19/2007 11:35:17 16° 2938 7
04/19/2007 11:35:17 15° 3000 7
04/19/2007 11:35:17 13° 3031 7
04/19/2007 11:35:17 13° 3063 7
04/19/2007 11:35:17 13° 3125 7
04/19/2007 11:35:17 14° 3125 6
04/19/2007 11:35:17 14° 3156 6
04/19/2007 11:35:17 14° 3219 6
04/19/2007 11:35:18 15° 3281 6
04/19/2007 11:35:18 15° 3313 6
04/19/2007 11:35:18 15° 3375 5
04/19/2007 11:35:18 15° 3406 5
04/19/2007 11:35:18 16° 3500 5
04/19/2007 11:35:18 16° 3563 5
04/19/2007 11:35:18 16° 3594 4
04/19/2007 11:35:18 16° 3625 4
04/19/2007 11:35:18 17° 3656 4
04/19/2007 11:35:19 17° 3688 4
04/19/2007 11:35:19 17° 3781 4
04/19/2007 11:35:19 17° 3750 4
04/19/2007 11:35:19 17° 3844 3
04/19/2007 11:35:19 18° 3844 3
04/19/2007 11:35:19 19° 3875 3
04/19/2007 11:35:19 19° 3906 3
04/19/2007 11:35:19 19° 3938 4
04/19/2007 11:35:19 18° 4031 3
04/19/2007 11:35:20 19° 4031 3
04/19/2007 11:35:20 19° 4156 3
04/19/2007 11:35:20 19° 4125 3
04/19/2007 11:35:20 19° 4188 3
04/19/2007 11:35:20 19° 4219 2
04/19/2007 11:35:20 19° 4281 2
04/19/2007 11:35:20 19° 4344 2
04/19/2007 11:35:21 19° 4438 2
04/19/2007 11:35:21 19° 4500 1
04/19/2007 11:35:21 20° 4469 1
04/19/2007 11:35:21 20° 4594 1
04/19/2007 11:35:21 20° 4563 1
04/19/2007 11:35:21 17° 4594 7
04/19/2007 11:35:21 17° 4625 11
04/19/2007 11:35:21 16° 4688 10
04/19/2007 11:35:21 16° 4719 10
04/19/2007 11:35:21 16° 4813 10
04/19/2007 11:35:22 17° 4813 10
04/19/2007 11:35:22 17° 4844 10
04/19/2007 11:35:22 17° 4938 10
04/19/2007 11:35:22 18° 4969 9
04/19/2007 11:35:22 18° 5000 9
04/19/2007 11:35:22 18° 5031 9
04/19/2007 11:35:22 18° 5063 9
04/19/2007 11:35:22 18° 5156 9
04/19/2007 11:35:22 18° 5156 8
04/19/2007 11:35:23 19° 5219 8
04/19/2007 11:35:23 19° 5250 8
04/19/2007 11:35:23 19° 5281 8
04/19/2007 11:35:23 19° 5313 8
04/19/2007 11:35:23 20° 5344 8
04/19/2007 11:35:23 20° 5438 7
04/19/2007 11:35:23 20° 5469 7
04/19/2007 11:35:23 20° 5469 9
04/19/2007 11:35:23 20° 5500 9
04/19/2007 11:35:23 20° 5625 9
04/19/2007 11:35:24 20° 5594 9
04/19/2007 11:35:24 20° 5750 8
04/19/2007 11:35:24 20° 5688 8
04/19/2007 11:35:24 23° 5688 8
04/19/2007 11:35:24 22° 5719 8
04/19/2007 11:35:24 24° 5750 8
04/19/2007 11:35:24 26° 5875 8
04/19/2007 11:35:24 24° 5781 8
04/19/2007 11:35:24 25° 5906 7
04/19/2007 11:35:24 25° 5938 8
04/19/2007 11:35:25 25° 5906 8
04/19/2007 11:35:25 24° 6000 8
04/19/2007 11:35:25 24° 6063 12
According to your mod list. You have no injectors or a fuel pump. Ive seen people put holes in pistons with a 16g at anything more then 15psi on an otherwise stock fuel system. Dont make anymore pulls until you fix that, or update your mod list if you do have those mods.
Your knocking way to much. Make sure you knock sensor is in proper working order. You should be pulling timing with that much knock.
thanks for the quick replies. i have a 190 pump on order should be here friday. i also have a set of evo 8 injectors that i need to put it. i checked for shaft play and there is some side to side but i cant tell if there is any in and out. where should i look to get my turbo rebuilt? there is a dsm shop down the road but they want $300 for a rebuild is that reasonable??? i think a little high.
ok heres my goals. i would like to be in the high 12's low 13s. would it be better smarter to go to a another 16, or sell my turbo on ebay and just buy a new turbo?? if so which one.
If theyll build your turbo and warranty it just do that. You dont need anything bigger than a 16G to run what you want to run, but more importantly you better get the right mods and tuning down or you wont be going anywhere.
