jonielGst
- 0
- Sep 27, 2010
Sterling,
Virginia
As the title says, my car got slow as hell right after i replaced the timing belt/water pump and the same day i decided to swap my t25 for a 14b.
When i was done with everything I took the car for a spin and i noticed i was leaking a lot of oil from the feed line (i forgot to upgrade the line). Anyway so the next day i decided to go back to the stock turbo. i started the car and it wasn't leaking oil anymore but i noticed it wasnt pulling hard like it used to.
I double checked everything and the timing seems fine. I did a BLT and i found a big leak from the throttle body so i replaced the 2 shaft seals (o-rings) and i noticed the car pulled a little bit better but still slow. Did another BLT and i didnt see no other big leaks.
i did feel some air coming from the oil dipstick tube (my dipstick broke and got sucked in) i dont know if thats normal though.
I just did a compression test and i got 145-147-160-160
I also re gaped the spark plugs to 0.28 (NGK iridium 6series)
Theres no check engine light. and Im going outta my mind because i dont know what else it could be.
97 Gst Running 17psi.
ANY HELP WOULD BE APPRECIATED
