My build...
Ppenguin2134
32
Oct 17, 2007
N/A, Pennsylvania
Ok, so I'm new to the DSM club. Had an Integra that was stolen. I plan on building up my 99 GST. Let me know what you think of my small soon to be setup and what I should expect to get out of it.
Parts List
-EvoIII Big 16g w/ Install Kit- Getting from a friend
-RC 550cc fuel injectors- $355.50
-Warlboro 255lph fuel pump- $109.00
-HKS Super Sequential Blow Off Valve - $279.00
-Injen IS Short Ram Intake System- $232
-Apexi AVC-R II Electronic Boost Controller
-Apexi AFC Neo Air Fuel Controller-
-GReddy Full Auto Timer- $88.00
-Apexi N1 3' exhaust- (already have)
-Apexi 3' Downpipe- (already have)
anything I'm missing? My goal is 280-300whp. Money is always an issue but I'm finding places with good deals. If you know of any better ones let me know. Thanks!!!
One thing off the top of my head that is missing is an adjustable fuel pressure regulator. That 255 will overrun the stocker and cause a rich condition at idle. Either get an afpr or go with a 190 which will be fine for your setup.
Also you may want to look into a tubular o2 housing to match up to your 3" dp, or port out the existing o2housing and manifold.
Your going to want to get a fuel pressure regulator with that list like tom said above. and if i were you i would consider getting a dsm chip or dsm link instead of the Neo.
and dont pay 232 for an injen intake. go to ebay and buy one from there if you want the injen style
Parts List
Looks perty good.. just a few things:
1. Check turbo first for shaft play ( because if your turbine blows apart your engine will get raped).
2. You could save yourself ALOT of money and get a gen 1 blow off valve( your gonna wanna re-circulate your B.O.V anyways so its gonna be quite either way).
3. Get a pocket logger or dsm link if your feelin spendy ( one of these is a must).
4.I would stick with 550's otherwise you have to get a dsm link to tune with.
5. Get the correct gauges, i.e. Boost gauge for sure because your stock one isnt accurate, oil pressure, egt perhaps.
otherwise good luck and welcome to dsm's :rocks:
:dsm::talon::laser:
Intercooler anyone? The 2g SSAC fmic can be bought for less than $300 and works great. Buy a 1g bov instead of the HKS and get a front mount. If not, are you going upgrade the sidemount or get hard pipes? Also I agree with everyone on the Aeromotive AFPR and I personally like A.C.T. clutches. A 2100 will fit your needs perfect. I am AWD, but I broke my stock clutch the first summer I had the car, and I was still on the t25.
