force inducted
- 0
- Feb 11, 2004
milan,
Michigan
ok guys im so friggin excited tomorrow is the big day for me so far in the build up of this car ....tomorrow i pick up my apexi afc my upper an lower intercooler pipes my intake pipe an my intercooler inlets an outlets an a evo o2 sensor housing ........last week i put on a 3 incj exhaust from the engine to the muffler an i threw a stainless muffler on the end ....it sounds great an made a noticeable power difference ...
ok now i have a few questions
1. what kind of hp gains should i excpect to see from the mods mentioned above
2. where would you go next keeping in mind i have 0 suspension mods an crap rims/tires.....
i think im done adding power till i get a better suspension/braking setup
o btw keep in mind this car will be my everyday driver an i want as long of a life out of my motor as possible ..so take that into consideration when suggesting mods
any helpful opinions would be appreciated
Next, what more proof do I need than FACT? Less pressure drop = less work for the turbo which DOES = lower outlet temps. Thats all there is to it. If your turbo is pushing 17 psi at the outlet, will the air be more heated (@ outlet) if you were running 21 psi? Yes. There is no arguing that point. Which PROVES that less pressure drop will lower temps, thus increasing horsepower. That is SOLID proof that cannot be argued. Piping and opened up outlets DO reduce pressure drop, therefore they DO provide a power increase.
) and I decided not to pursue this any farther. Its obvious that we both have strong thoughts on the matter and there is no convincing either of us.
