massive electrical problem
Turbski91
619
630
Jul 25, 2011
gilbertsville, Pennsylvania
Hey guys, I have been having some problems with my electrical lately and have not been able to figure any of it out. First a few months ago I went outside and turned the key to the on position and the radio just shut off and now the turn signals dont work but when you press the flasher button the lights on the insrtament panel stay on with a wierd buzzing noise, and also when the key is in the ignition it seems as if there is a wierd buzzing noise comming from the ignition. I have no idea I'll post a video of it later once my ipod charges. :confused:
yes everyone is good, the problem is that when I turn on the turn signals the relay starts buzzing, and the light on the instrament pannel blinks rappidly, but when I try to use the hazard button those lights just stay on and the same buzzing noise occurs. I have no idea what to do?
May I suggest start pulling relays and fuses going to those circuits one by one. Remember to make a note where each part you have pulled, came from. Start with the easiest ones first then work your way throughout the circuit(s). Have someone help you while your pulling them and check to see if that makes any difference. You may have a circuit that is cross feeding current to the ones your having problems with. Only way to know is if you isolate the circuits that is giving you problems.
Ok I will have to do that and check back!
Ok so I tried doing that and nothing but the turn signal fuse shuts off the buzzing... so I guess that means that my short short is in that circuit?
Correct, that is one problem you have found. Since you had the dash out, recheck for any grounds that may have been overlooked during the install. You may have pinched some wires so would not hurt to do a closer inspection near and around the area(s) that you had been working on.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
