Massive DSM Part Sale
95AWDTalonTSI
31
Oct 15, 2012
Platteville, Wisconsin
Parts located in Platteville WI
ALL ENGINE PARTS CHECKED BY MACHINE SHOP
7 Bolt Factory Parts
$20 2G Intake manifold with throttle body, sensors, and coil pack
6 Bolt Parts
$50 6 Bolt ARP Head Studs
$80 Standard block can stay standard
$30 Standard crank needs ground (0.010)
$10 Front case assembly with balance shaft deletes
$20 2 or 3 Good factory big rods with 3 good standard pistons
Drivetrain Parts
$20 Stock Clutch used but useable
Electronics
$90 2G EProm ECU Good Condition
$25 2G Alternator brand new
Cooling
$25 2G Radiator with fans Good Condition
Turbo
$20 1G Blow Off Valve Uncrushed Good condition
$20 EMusa 38mm Wastegate with Heat Wrapped Dump Tube
Call or text for more details.
(60EIGHT) 21FOUR-421EIGHT
<a href="http://s815.beta.photobucket.com/user/92camaroRS/library/" target="_blank" rel="nofollow"><img src="http://i815.photobucket.com/albums/zz73/92camaroRS/photobucket-52698-1352474633448.jpg" border="0" alt="2012-11-08_15-31-45_922"></a>
^stock clutch
Tags: dsm ,1g, 2g , talon ,eclipse, mitsubishi, eagle, 4g63, 4g64, door panels, doors, shell, awd, all wheel drive, project, swap, axles, rear end, gas tank, brakes, driveshaft, transfer case
