2G Lowering Problem
javierabrahamgv
88
Mar 31, 2014
Santo Domingo, Central America
Hi guys,
My car is not lowered, I have 18 inch rims but changing them to XXR 527 18x8.75 +35mm, planning on putting them with 225/40/18 tires. Ordered Megan Racing lowering springs which have a 2" drop.
Something I just noticed is this bolt on top of the the tires/rims I have now without lowering it. Won't this affect me when lowering it?
The distance from your axle to the bolt head does not change with lowering springs. It's a fixed length not effected with lowering springs. Only larger diameter tires would cause you a problem with hitting that bolt/nut.
Phew! Thank you guys, was getting kind of worried after buying everything jaja.
Do you think I would need to roll the fenders?
Might. Those springs are pretty weak & might not be able to stop your wheel before rubbing on bump.
Most likely with a full 2 inch drop just springs will make the car bouncy and you will need to roll them. I have the same wheel size except it is the xxr530 however i have coilovers which makes everything nice and stiff and i only rub on big dips in the road.
http://www.dsmtuners.com/threads/just-a-little-teaser-xxr-530.476518/
(Pics are at the bottom)
Very nice! I wanted the same coilovers but there's an issue:
Re-sell: In my country there are around 10-12 Eclipse and the guys who have them, don't spend much money on it, so if for any reason down the line i would need to re-sell them it would be extremely hard. Since i'm not planning on selling the car, i will be purchasing them but the car has other priorities at the moment so the springs will have to do in the meantime jaja.
Thanks man for the info.
