Losing Clutch Fluid but not losing clutch?
BigAirSkier1580
92
Mar 31, 2004
East Aurora, New York
I'm leaking my brake fluid for my clutch, however, I can let the resevoir run dry, but I won't loose the clutch. It gets softer, but it will still work. Where should I start looking for my leak so I can get this problem fixed before springtime comes..
Oh, and it's a 2g TSi AWD with an ACT 2100 if that matters at all.
you could also check the slave cylinder and all of the fittings between the two. Also check the bleeder, make sure its tight or not broken. and its not a good idea to let the master cylinder run dry. If it was completely empty your clutch would not work so there has to be some fluid in there.
