For Sale Long list! Will Ship or Deliver to shootout!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
Call or txt 304-813-2405 for more info
Located in Morgantown WV
Will ship anything.. Will deliver to SHOOTOUT for free
EVO 8 Steering wheel w/ airbag - $225
Omni 4 bar map sensor (MDP Style) - $50
Used 6 bolt head studs - $50
Fuellab Prodigy fuel pump - $325
Anodized 2g awd Full Blown double pumper (-8 feed -6 return) (no pumps) - $325
AEM Wideband - $125
Hallman MBC - $50
Fuel lab afpr with line and fitting and gauge - $130
Aeromotive AFPR with line and fitting and gauge - $130
SS o2 housing w/ Tial F35 external dump - $225
SS o2 housing w/ open dump - $75
Brand new unopened Tial MVR 44mm black wastegate - $335
Red Fuel lab -6an inline fuel filter w/ Adapter fitting for stock fuel line - $75
BBK 62mm DSM Throttle body w/ TPS IAC FIAV (ports on top are blocked off) - $175
Weapon R 2g SMIM CNC Velocity stack(Painted red but easily comes off) - $325
1g Cas in a 2g cable - $45
2g Walbro 255 - $50
1g Walbro 255 w/ install kit - $50
1g flanged Forge BOV - $75
1g Sparktech COP Setup(91-94) - $325
2g Home made COP Setup - $225
2g Coil on plug setup(300m coils) - $200
Black fuel lab AFPR with rail kit and gauge - $130
Aeromotive AFPR with rail kit and gauge - $130
2g VRSF Intercooler kit with piping - $275
AEM TRU Boost gauge (missing the boost control solenoid/harness) - $125
AEM Digital Boost gauge - $110
Walbro 400 Pump - $90
Good 6 bolt long block - $900
Good 2g FWD 5 speed transmission - $400
BBK Throttle body w/ all sensors - $200
Garrett t3 57 trim - $400
Built 6 bolt short block - $2500
Manley Turbo tuff rods
Manley 9.2:1 compression pistons
Eagle crankshaft
Kiggly girdle
ARP main studs
Water Pump
Oil Pump
Oil Pan
Timing components
Includes everything from the deck down ready to drop a head on it and go
FIC ASNU 1050cc hi-z injectors cleaned & flow tested - $400
FIC 1150cc Low-Z injectors (Cleaned and tested) - $255
1990 EPROM Converted ECU - Recently converted and tested at ECMTuning - $175
1990 Socketed EPROM ECU - Motoguys - $175
1991-1994 Socketed EPROM ECU - $175
Complete 2g Auto Swap (Includes everything you need to make a 2g manual AWD an Auto AWD) - $1250
Complete 1999 Split thrust long block Stock w/ 82K miles on it - $1000
1g Walbro 255 - $50
2g walbro 255 - $50
2g Skunk2 coilovers w/ Tokiko Blue struts - $475
Brian Crower 288 Cams - $325
HAFE manifold rev3 Cast SS (BEPDSM7) (Has not been drilled for external wastegate but easily done - $225
Used Tial MVS (38mm VBand) Black - $200
New 2g Punishment racing intercooler kit(Mounted but never ran) - $300
6 Bolt ARP Head studs - $50
7 bolt ARP Head studs - $65
2g ECMLink SD harness - $50
BLE Solid timing belt tensioner(6 bolt) - $90
Used DNP Style(No name) DSM Flanged tubular exhaust manifold - $50
JPipes Jpipes Jpipes - $25
holset H1c parts turbo has some turbine damage, turbo came loose from its housing- $50
Built 6 bolt short block- $1600
good 6 bolt shortblock - Has some vertical scratches in the bores nothing terrible engine had 165-170 compression across the board and did not smoke or carry on - $550
Garrett GT35R Dual Ball Bearing T3 4bolt out - $850
Brand new 2g/EVO Oliver Billet Ultralight rods - $750
Billet Unorthodox Aluminum crank pulley - $40
Used MHI 13g turbo - $75
Used MHI 14b turbo - $110
Used T25 turbo - $115
Weldon Inline fuel filter -6an $75
97-99 2g AWD 5 speed trans (pops out of first) good core unit- $350
Good used act 2600 clutch with street disc - $225
ACT 2600 pressure plate - $125
ACT 2100 Pressure plate - $125
2g ECMLink GM MAF Harness $65
Evo 8 K&W typhoon intake system $50
Act Streetlite 7bolt fwd flywheel - $100
Braille - Small battery tie down/tray - $85
Good 2g MAF - $25
2g Lamborghini style bolt on door hinge assemblies - $250
os giken DSM twin disc clutch - worked well but will need a rebuild - $450
Revised 3g Lifters - $65
Holset HX40/35 hybrid w/ 12cm T3 Housing (Rebuilt by Justin Whitesell 2000 miles ago) - $475
2g LSD Manual rear diff - $225
1g 4 bolt rear axles with cups - $225
2g pair LSD rear axles $200
2g LSD Auto Rear end - $225
2g Non LSD Auto Rear end - $200
2g 91-96 Auto Tcase - $175
22 spline manual tcase - $150
23 spline manual tcase - $175
97-99 manual tcase 23 spine - $175
Good manual half shafts w/ carrier - $75
Cleaned and flowtested Stock 450 DSM injectors(Blue tops and black tops) - $75 per set
Cleaned and Flowtested Rc 550 injectors - $100
Cleaned and Flowtested 750cc injectors - $200
1g AWD Fuel Sending Unit - $100
2g AWD Fuel Sending unit - $100
2g non abs prop valve w/ hard lines - $80
1g non abs prop valve with hard lines - $80
2g complete core head (Running pull) $225
1g Complete core head (Running pull) $225
Recently rebuilt to stock 1g head - $300
Good 2g short block 95-96 Running pull $550
Good Engine harnesses (1g/2g Auto and 5 speed available) - $175
Cars for sale - (Search for my other ads in the group to see more specifid etails)
1990 Talon TSI AWD - 126K miles Mostly stock - 16g FMIC, Exhaust.. $3200
Located in Morgantown WV - - MUCH more not listed PLEASE CALL OR TXT
304-813-2405
