For Sale Long List of DSM and EVO Goodies!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
Dont See it ask - You can place orders on our site! www.rixracing.com
7 bolt awd Fidanza Flywheel 75
6 bolt ACT Streetlite AWD Flywheel 125
2g Spyder Parade Boot (Black) 200
1g Sunroof Visor 100
7 bolt built 2.4 shortblock 2250
Rebuilt 6 bolt shortblock 2250
7 bolt arp head studs - new in box 105
Rebuilt to stock 2g head 375
Refreshed 2g Head with BC Springs and retainers 500
Refreshed 2g Head with Evo 9 springs and retainers 450
Built 2g Head - Kiggly "Street" beehives and Stainless Valves 700
Devils own Methanol Pump 40
Aeromotive AFPR 125
Twin Scroll T3 HX35 Turbo, exhaust manifold, and wastegates combo 1500
HKS Purple Timing belt 100
Gates Racing Kevlar Timing belt 50
1g aluminum radiator - 2 row 100
2g Aluminum Radiator - 2 row 100
2g Billet Brake Reservoir Bracket 100
TurboXS Boost Controller 45
ACT 2900 Maxx Extreme with 4 puck unsprung 325
Brand new AEM Infinity 508 with evo 8/2g dsm jumper harness 1400
Manley 7 bolt forged crankshaft 500
PTE 5031e Turbocharger 375
RMS Top Mount T3 Exhaust Manifold 900
Kelford 280/276 cams 500
Silver AEM Cam Gears 150
7 bolt awd act streetlite flywheel 125
97-99 Automatic Tcase 200
DSM Automatic transmission Planetary and sun gearset 150
ATI Super Damper 325
Competition Clutch 6 bolt FWD Triple Disc Clutch set 1350
Rebuilt 1990 Non Eprom Manual ECU 80
1998 Eagle Talon TSI AWD Roller 750
2g maf with K&N Filter kit and snorkel 85
2GB 97-99 14 turn 300M automatic transfer case 1350
2G Precison torque converter 850
2g Coil pack 60
Apexi Turbo Timer 25
AEM Volts Gauge 85
TT Racing 2g Radiator Hoses 35
DSM Fuel rail with filter and fittings 140
9 gallon Fuel cell with AEM pumps and valves 400
2g DSM Tein Street Basis Coilovers 600
1g dsm center pillar trim 10
Valve cover with catch can 275
2g timing side bracket 40
Aeromotive a1000 fuel pump 300
Shepherd Racing 2g FWD Transmission with Quaife LD 2250
2g FWD DSS Level 5 Front Axles 1350
AEM X Series Wideband Gauge 150
Aeromotive AFPR 125
Dejon Tool Intake with recirc fitting - Prismatic Diamond Blue 100
3” Inlet Intake - with recirc - Powdercoated Prismatic Gloss Black 90
Refreshed 6 bolt Longblock 1500
FP recirc Intake pipe with K & N filter 140
1997-1999 Automatic Tcase 175
1g Turbo Water pipe 70
2g Throttle Body 10
STM EVO 8 / 9 oil feed kit for JB Turbos 50
DSM Intake Pipe - Powdercoated Black with light purple rainbow shimmer 65
NEW OEM Rear Floor Mats for EVO 8 or 9 40
AEM Tru Boost Gauge / Boost Controller 225
Knock Off HKS SSQV With pipe 50
2g DSM Speed Density harness for use with AEM style Map sensor 50
3” recirculated Intake pipe - powdercoated metallic red 90
1g dsm center 2 gauge bezel 35
2g Water pipe - powdercoated black 70
ID 1000cc Hi-Z Fuel Injectors 400
stock 7 bolt awd flywheel 40
Single AEM Cam Gear - Silver 50
97-99 MPI Relay 35
Spoolin Up IAT Harness for EVO Speed Density Setup 25
2 Stage Boost Controller - TurboXS 75
1g door weather moldings 50
1gb Talon Talon Tail lights 100
1g 1990 recently rebuilt DSM 5 Speed manual Transmission w/ Welded Center diff 1200
ID 1000cc Hi-z Fuel Injectors with Pigtails and resistor delete plug 400
2g non-abs prop valve 55
2g hood latch and cable 75
2g Water Neck / Thermostat Housing 35
Injen Intake pipe 80
PTE 6870 T4 Twin Scroll Kit with Mani Gates and more! 3000
Very Clean 1995 Mitsubishi Eclipse GST (AWD Converted) 3000
Skunk 2 pnp Coil on Plug for evo 8/9 265
EVO - Passenger side inner axle 40
EVO - Driver side inner axle 40
EVO Steering Wheel - No airbag 125
DNP Twin Scroll T4 Exhaust Manifold with freshly rebuilt PTE 6765 Turbo 1700
Tein Lowering Springs - Evo 125
Red Perrin Crank Pulley - EVO 50
Red Perrin Fuel Rail - EVO 100
EVO 8/9 Sweitzer SMIM with Boomba 75mm Throttle Body 775
Lightly used Greddy Kevlar timing belt 55
PTE Low-z 1600cc Fuel Injectors 265
EVO Front and Rear brakes with adapters for 2g DSM 675
PTE 6466 Gen-2 DBB Vband in/out .82 ar 1750
Kinectic/SBR 2g "short route" FMIC Core 350
4 bolt manual rear diff w/ axles and cups 375
Built 6 bolt shortblock - Eagle Rods Wiseco Pistons 1800
Braille Small Battery tray 65
Air horn kit! 50
FP Super 99 in T3 .85 Housing! 1200
2g GST Fuel Sender 40
Shurflo Methanol Pump 40
EVO 8 \ 9 Aluminum Underdrive Crank Pulley 40
MSD Digital Window Switch 65
HKS Turbo Timer 35
Evo 8 steering wheel has wear on top 200
Front passenger side fender evo 8 9 150
EVO 8 / 9 Carbon fiber dash inlay 125
Oem evo 8 rear bumper 200
Yellow evo 8 9 trunk lid with spoiler 300
Black evo 8 9 trunk lid has holes for spoiler 200
EVO SSL Amp and Subwoofer 200
Yellow driver side fender 200
ACT 2600 clutch cover 125
Healthy 2g Knock Sensor 50
EVO 8 Blue Cloth interior - Fair Shape 300
Evo 8 / 9 Rear Differential - only 24,500 original miles! 800
EVO 8 / 9 Cusco Rear Sway Bar (25mm) 200
Used Working ACD Pump 350
Brand New in box ARP L19 Head studs 225
EVO 8 HKS 264/272 Cams 325
FIC "EasyTune" Box 325
2g Manual NON LSD rear diff 200
Oem EVO 8 Tail lights 200
Evo 8 valve cover 200
2g gauge cluster 65
ECMLink v3 GM Maf wire 50
22 Spline Manual Transfer Case 150
Good Used Saturn Alternator 50
Blox Evo 8/9 front rollstop 50
2g Alternator 45
Rexspeed Carbon Fiber EVO Armrest Cover 100
DSM 450cc Injectors 90
CRACKED! Valve cover with -10 an fittings 100
Polished valve cover with -12 weld in vent 225
Sheepy 850 HP Intercooler core 425
Precision 6766 Turbocharger - .82 AR T3 Turbocharger (Journal bearing) 885
Black Tial MVS 38mm Vband wastegate with clamp 225
ARP 'L19' Head Studs for a 7 bolt 200
Brand New Precision 6870 .96AR Vband turbo 1900
BSFab V-Band Bottom Mount Exhaust Manifold(T4 equivalent V-band) 1000
EVO cluster with 24551 miles 425
Fp Exhaust Manifold with Hardware 225
Mitsubishi Badged Valve Cover 125
1g Tubular Lower Control Arms 100
1997-1999 Manual transfer case 200
2g Crank Angle Sensor 40
95-99 Auto Trans Mount Powdercoated Black 100
Greddy Blow Off Valve 100
1g Driver side mirror 35
2g Water Pump pulleys (powdercoated black) 65
1g water pump pulleys (powdercoated black) 65
2g DSM Shift Cables 100
Genuine HKS SSQV blow off valve 90
FP in line oil Filter and restrictor 35
DSM Starter - for auto transmission 50
2g 7 bolt oil filter housing OFH 40
2g Throttle Position Sensor 30
Oem Harmonic dampner 50
6 bolt oil pan 50
1991-1994 cluster 45
ACT 2100 Pressure Plate 125
Unorthodox Racing Aluminum Crank Pulley 40
Good 1995-1996 MPI relay 25
Fuel Lab "Prodigy" Fuel Pump 475
DSM Idle Speed Controller 50
1g Stock Intake Manifold 35
2g alternator tensioner arm 20
2g Manual Speed Sensor 35
EVO Spark Plug Cover 25
EVO 8 / 9 Exhaust Manifold 75
2g black airbag 75
EVO 8 / 9 Dashboard w/ Passenger side airbag 150
EVO 8 / 9 Exedy Twin Disc - Needs Rebuilt 200
2g Mass Airflow Sensor - MAF 25
EVO 5 speed shifter base and cables 150
6 bolt oil filter housing 40
2G TCU 50
2g shifter and shift cables 125
2g throttle body with sensors 65
Rix Racing T-Shirt 25
