logger logger pocketlogger
ITSME4G63
3,427
Feb 6, 2004
chicago, Illinois
Hey guys,
I recently received a pocketlogger/datalogger palm combo from a friend. I downloaded the software and installed it onto the pocketlogger. Now when I plug it in the diagnostic port, the vitals on the pocketlogger are as if I never plugged it in, nothing shows. Could there be a problem with my diagnostic port or has this ever been heard of with a logger? Ive used this logger about 6 months ago, the same one, to check out my car and it worked. Maybe when my security alarm was getting installed on my car, they messed up the wiring of the diagnostic port? Any input appreciated.
ITSME4G63 said:
Hey guys,
make sure its registered or it wont work.
ITSME4G63 said:
How would I go about doing that? thanks.
well you have to know the code did you get that from your buddy?
just hit the drop down menu and put your code in.
does it say unregistered in on the main screen
what software are you using? i use mmcd on my palm m100 and i thought it was screwed up at first because none of the categories would show up like rpm, knock, and all that. i found out that i had to actually select the category i want then also select the dotted line next to it fo it to display results.
I may need to try that, but Idfk anymore
If it is the pocketlogger program. You need to get the serial code off of the cable that goes to the data link connector on the car. There is a page to fill out on digitaltunings site. Input all of your info, and the registration number will be sent to you.
