Knocking/Thumping from under Car.
TheTSiGuy
989
Nov 5, 2003
Naperville IL, Illinois
I have a knocking/thumping coming from what seems to sound like the front of the car. At first I was thinking driveshaft or carrier bearing, as i was traveling at higher speeds, but even at low speeds it does this..
what are the symptoms of bad wheel bearings?
Also, the steering wheel is shaking quite a bit, and turns are alot harder now. Not sure if its the same problem though.
Help!
Thanks!
Jim
  • Wanted 6 bolt NT water pipe
    • chrisman287
