jamel16
- 420
- 581
- Aug 6, 2004
Richmond,
Virginia
Good evening tuners, I have some JE 2.3L stroker pistons for sale. I purchased these as a set of three from a warehouse sale. These pistons are brand new in the plastic with everything included for installation. I was going to use these in my stroker build but found out I would have to bore my block out to 87mm. I priced a single piston for 180.00 from MAPerformance . I’m only asking 300.00 for the set of 3, A full set goes between 620.00-700.00 so here is your chance to get some awesome pistons for the low.
JE Pistons, Mitsubishi 1993-99 Eclipse/Talon/4G63 22mm pin, Bore 86.0mm, Stroke 100mm, Rod Length 150mm, Dish -23.3cc, Grams 286, Set of 3
JE Pistons are machined by the most advanced CNC machining technologies available. JE forged Pistons are trusted by racers and engine builds for dependability. JE Pistons are compatible with boost and nitrous.
Crown requires no deburring or preparation
2618 T6 high tensile forged aluminum
NEW ASYMMETRICAL FSR forging! State of the art asymmetrical skirt technology reduces friction and mass while providing a more rigid and durable platform (Skirt Style F).
In this environment, higher boost levels or heavy nitrous usage necessitate JE's wrought 2618 alloy.
FSR pistons include offset pins for quiet operation.
Dished pistons feature new Smooth Finished Crown process for excellent flame travel.
1.0 x 1.2 x 2.8mm ring widths
.866 x 2.250 straight wall carbon steel wrist pin provided.
Pin fitting and wire locks included
Part numbers 208477 & 254006 have 1.2, 1.5, 3.0mm Ring Pkg (Skirt Style R)
Compression Ratio:
8.5:1
I will put this out before hand, I don’t deal with PayPal, that company left a very bad taste in my mouth. I do accept money order, cash app, Apple Pay , Venmo, or zelle. I have been on tuners a very long time and my itrader rating speaks for itself. The only shipping methods I use is FedEx and UPS due to the USPS backlogs.
You can contact me through text 434-941-4568 or PM.
Compression Ratio:
8.5:1
