boiseDSM
- 0
- Mar 17, 2005
Boise,
Idaho
ISSUE:
So, I've had this incredibly difficult starting issue on a basically stock 90 tsi. The colder it is, the worse off the starting. It takes awhile to crank and eventually will catch (barely) but then dies. Another crank and it catches a bit more. Repeat 10 or 12 times until it stays idling. Once warm though, it starts right up. The starting difficulty seems to be a direct function to how long the car is sitting cooling off.
I've noticed that I get a CEL while driving after about 30 seconds of the engine running. I also found out that the CEL also turns on an after 30 seconds with the key turned to the acc. position but not started.
DIAGNOSIS:
I'm betting it is a coolant temperature sensor. Seems like the only way a CEL could get thrown with the ECU on but the engine not running is if there is a dead sensor. This would then explain why it runs bad when cold and hard to start. Am I thinking along the right lines here??? I haven't had the time to really take a close look. Just wanted to know what people with more DSM knowledge than I have might think about it.
Thanks guys
DIAGNOSIS:
Thanks guys
