16g Spoolin TSi
- 126
- 0
- Feb 19, 2004
Merrimack,
New Hampshire
I want to pick up the 52mm Greddy EGT gauge however it says it ranges from 300c- 1200c.. is this enough of a temp range, im more concerned with the higher temp range
and it is true that the Greddy 60mm gauges won't fit in the regular gauge pillars?
BTW is the Autometer boost gauge better than the VDO or are they the same as for accuracy?
AND lastly if i was to install an oil pressure gauge does it require a new sending unit?
Some guidance please
~Johnny
and it is true that the Greddy 60mm gauges won't fit in the regular gauge pillars? BTW is the Autometer boost gauge better than the VDO or are they the same as for accuracy?
~Johnny
