Is it possible...
GSTdOff
99
Dec 30, 2003
Florence, Arizona
...to interchange 4g63t parts with a N/A 4g63? I.E. 4g63t head on a N/A 4g63 block or vise versa?
Since the only difference is the piston compression ratio and exhaust manifold yes.
A NT 4g63 is still a 4g63. The turbo engine is'nt that much different.
yes.
Yes? How do you know this?
As far as I know, the blocks are the same casting, which would mean the exact same oiling and cooling passages.
NT blocks are not tapped for oil squirters though.
So a non turbo block wouldn't be ideal for turbo applications because of the oil squirters?
Yes.
Just get some squirters and install. Just a little drill and tap operation.
  • Wanted 6 bolt NT water pipe
    • chrisman287
