Installed TT, now im getting a CEL
T is for TURBO
2,250
25
Jan 15, 2005
Milwaukee, Wisconsin
just like its titled... I Installed a Turbo Timer (with the harness) and now I have a check engine light. Any ideas why? Is there a way of checking what the light is on for with out a datalogger?
Thanks!
-Shawn
BTW is a GReddy Full Auto Timer
I think if you figure out the cel it will make the problem more apparent. Just go to autozone or a similar parts store and they'll run a code check on it for free. If you still can't figure it out then let us know
So I took the car to Batozone and this is what they came up with... (ill scan the print off when i have time)
Trouble OBDII (Alpha) P code
Troubleshooting P1105
Dual Alternator Upper Fault
No idea what that means... But on the computer they used, it read something like "Fuel Air Meter"
any Ideas?
Happy St. Patties day
-Shawn
P1105 Open or shorted condition detected in the baro read solenoid control circuit
Got that from www.vfaq.com
Did you unplug any of the solenoids on the firewall when you were installing this? If so that could be your problem.
No i don't think so. I just did a search and all the other people having this problem had a bad fuel pressure solenoid and had to replace it. I would bet that would fix the problem for you as well.
One thing you should remember is that installing something that in turn seems to cause a problem could be just a coincidence. For example, I replaced all my vacuum lines in my car and then the same day my tranny went bad. Thats a stupid example but i think you get the point.
