Inside Timing Cover Oil Leak!
dsmpokolm
176
Jan 29, 2006
Calgary,
I have searched oil leak in the forums and wow there are a bazillian threads. I dont think any of them are like mine though. I want to know all the places oil can leak from inside the timing cover on a 2g. Crankseal is an obvious one. I have the BS removed if that helps. Please help me out this is driving me nuts!!! Thankyou!!!:)
Alot of those aren't from inside the timing cover? isn't the Front Main Seal the same this as the Crank Seal?
Valve cover, head gasket, bs shafts, oil pump, front man seal, crank seal, oil filter housing, oil filter, oil pan, oil drain for turbo, there is probly one or two i am missing.
oil filter housing, oil filter, oil drain for turbo, are outside the timing cover.
