Injector and manifold question
drk mrk iv
238
Jul 31, 2004
Charlotte, North Carolina
I am buying a t28 killer today with 30k miles on it. I have my stock manifold and the turbo is ported to 7cm. Would it be a good idea to bolt it up to the manifold or just wait until I get a 7cm one. Also, I bought some evo8 injectors to help with this settup as well. One of the O-rings is busted. I am going to go to NAPA today and buy 4 new Orings for all 4 of the injectors. Anything else I can do to... Clean up these injectors? Dip them in injector cleaner or something?
Although the Evo8 injectors are probably fine, I wanted to be 100% sure of the set that I got a while back, so I sent them here:
http://www.cruzinperformance.com/fuelinj.html
For the small cost, you can't beat having them cleaned and flow tested. -You might want to hold off on those o-rings, as I think that I got a new set that was included in the injector service.
Why can't you just port your existing manifold while it is off of the car?
