Idle is bad.....everything else is perfect
Spyder50Trim
Dec 3, 2005
Buffalo, New York
I have everything in my mod list, well the problem is, i turn on my car and it starts off idling at 1k then in like 2 sec goes up to about 2-2500 rpm and idles there. Im wondering if its just time to get a afpr or is my tps off? if anyone could help thatd be great, evertyhing else is running perfect just my idle is high.
ps- its not the throttle cable being to tight either
your TPS is most likely off.. pin 1-4 should read ~5k, pin 1-2 should be at the point of continuity and non-continuitiy, pin 1-3 (this is particular to my car, but should give you an estimate) is at ~.68k ohms when i'm at teh sweet spot.
check your ISC motor also via resistance test..
  • Wanted 6 bolt NT water pipe
    • chrisman287
