I need help with a swap
Jeversole
Feb 23, 2011
columbus, Indiana
I need information on a swap? My eclipse needs a new motor. I was thinking about a turbo motor and a new transsmision. Heres the problem. My transmission is on the right side and all the engines I have looked at are on the left side. Please help I have no idea where to start or the parts needed.
The "other" cars have the transmission on the other side, because they have a 4g63 turbo motor.
You have a 420A non-turbo motor, which is totally different from the Mitsubishi 4g63.
420A's are a completely reversed.
If you do some searching, there is a lot of info on turbocharging the 420A.
Some people will tell you to just sell it and buy a turbo model.
But that is up to you to decide.
Just so you know, it is next to impossible to swap a 4g63 turbo motor into your non turbo chassis.
http://www.dsmtuners.com/forums/420a-bolt-tech/293697-97-talon-n-t-turbo-conversion-questions.html
http://www.dsmtuners.com/forums/420a-bolt-tech/308271-turbo-my-gs.html
http://www.dsmtuners.com/forums/420a-bolt-tech/257212-pics-your-420a-turbo-setup.html
Ok hereis more info..... I.m gunna put the evo 4 or 3 silvertop. Now I need new/customs axels and maybe a new cross member. Imgetting the motor from canada they have everything I need, but the axels, any sugestions.
