How to remove sensors off the Inejectors?
TooFastTooG
521
6
May 12, 2004
Plainfield, Illinois
I can't get these damn things off, I need them off cause im replacing all the seals due to a boost leak, it looks like I need to push in on the two sides but thats not working. Any ideas on how to get these off? :mad:
I believe you have little u-pins right? You just need to pull the pins out. I recently swapped injectors with my buddy, he has a 95 GSX and I have a 97 GST. He had to pull out those little pins whereas I just had to squeeze the plugs. Don't loose the pins. Use a small flat-head screwdriver or a knife even to get 'em out.
When you posted "senors" you meant the injector harness, right?
Mister Spool is right, just slide out the l_l pins. But why are you replacing the injector o-rings due to a boost leak? That wouldn't be my first place to look.
