how do i wire up dual horn buttons for seperate uses?
Awoler
116
May 11, 2003
montgomery, Alabama
i got one of those 2 button steering wheels and i would like to use one for my line locks and the other for my elec. boost controller .but i cannot use both off the horn hook up because then ever time i go to high boost my line looks would kit on, right ?or is there some way around this?i'm not the greatest at wiring....
all those buttons do it goto ground - ya would need a clock spring with more then 1 circut
the horn buttons don't ground at the switch, however, they just have two wires that connect to the frame of the steering wheel. So if you run new wires, you could definately use them.
Each has a purple and black wire coming off of it. The black goes to the metal which grounds when you install the steering wheel. The other, joins together to connect with the wire that goes to the horn.
i did explain - if there are any more questions relevant to the post please ask
