Hks Evc........big Problem.......please Help
turbodsm18
675
4
Jan 26, 2005
816/417, Missouri
I just bought a hks evc. I hooked it all up and it work perferct. But then all the sudden it shut off and now it wont turn back on. When i start my car it beeps but thats it no power or nothing.
Someone please help.
I hook the boost controller up and turn the ignition on and It will beep and flash the green light but then just powers itself off. I tried to reset it but i cant even get it to power on.
Any body , just throw out some suggestions. Thank You!!!
Man I don't know. It sounds like something is wrong w/ the EVC. You might want to call HKS tomorrow and talk to tech. support tomorrow.
That's hard to know what's going on with that. I had an EVC IV where the actual unit would turn on, but then it wouldn't boost correctly. Later I found out that the solonoid was faulty. If the unit does not turn on properly with the correct voltage and ground connections (which you should double check), then something on the circuit has been fried.
Good luck!
