trackbeast
- 0
- Apr 10, 2013
Daly City,
California
hey guys new to the dsm world. Anyways i used to have a number of cars i had an evo 8, 7 conquest tsi's, an ae86, corrado vr6, and a couple sports bikes. Anyways i just got this DSM for free. It was owned by a girl who had some work done to it. but here is a list and tell me whats good. its a 91 talon tsi AWD.
Intake/Exhaust:
- Forced Performance Ported Evo III Exhaust Manifold (7cm)
- 16g Turbo:
- Ported Turbine Housing (7cm)
- Ported Compressor Housing
- Ported Wastegate
- Buschur 16g Turbo Outlet Elbow
- K&N Filter
- Removed Air Can
- Removed Lower Honeycomb
Motor:
- Polished Head
- Crower SS Intake Valves
- Crower SS Exhaust Valves
- Crower Springs
- Titanium Retainers
- 2G Big Bore Lifters
- ARP Head Studs
- Mitsubishi 4 Layer Metal Head Gasket
- Valve Bowls and Back Of Valve Seats Smooth
- Silicon Bronze Valve Guides
- 3 Angle Valve Job
- Stock Original Block
- Buschur/Hallman Manual Boost Controller (12 psi)
- Magnecor Competition 8.5mm Wires
- NGK Bpr73s Plugs (part# 2023) NGK Bp7es Plugs (part#1034)
- RRE Stainless Steel Turbo Oil Supply Line
Electronics/Interior:
- Apexi Turbo Timer (Pen Style)
- Apexi 60mm Boost Gauge (White)
- Autometer Single Gauge Pod
- 1999 GSX Stock Leather Shift Knob
Drive Train & Suspension
- Dave Symbroski Metal Shift Bushings
- Mofugas Short Shifter Cut 1 Inch
- ACT 2600 Clutch With Organic Street Disc (Spinned Balanced)
- Fidanza Flywheel (Spinned Balanced)
- RRE Stainless Steel Braided Clutch Flex Line
- BG Syncro Shift (Tranny)
- Red Line Heavy weight Shock Proof Gear Lube (Transfer case)
- Red Line Heavy weight Shock Proof Gear Lube (Rear Differential)
- Tein S-Tech Springs 1.2 Fronts 1.6 Rears
- KYB AGX Adjustable shocks (4Way Front) (8 Way Rear)
- ½ Wheel Spacers (Rears)
- Kyo-Ei 52mm Extended Wheel Studs (Rears)
Miscellaneous
- RRE Catch Can
- 2G Exhaust Manifold Heat Shield
- Silver Star Headlights
- Eric Plebani Oil Cap
Intake/Exhaust:
- 16g Turbo:
- Ported Wastegate
- K&N Filter
- Removed Air Can
Motor:
- Polished Head
- Crower Springs
- ARP Head Studs
- 3 Angle Valve Job
Miscellaneous
- RRE Catch Can
