Help W/ Installing Exterior Parts
99EXTACY
Sep 22, 2004
Toronto,
Hey this is my first car and I don't have much experience doing my own body/engine work. I am installing the OEM turbo spoiler on my 1999 gs eclipse and I had to take off my 3 piece first so any help on how to mount the turbo one would be of great help to me and also there are about 8 holes on each side of the trunk left from when I took the 2 outer pieces off and one big hole in the middle of the trunk from the middle piece. How would I go about filling these would I use plastic or epoxy filler and how do I do this? also, any help on installing a urethane blitz kit and fibreglass z3 fenders would help alot...THANKS
To put on the new wing you need to center it up on the hatch as far up or as far back as you want it. use a tape measure and find the center of the hatch, then find the center of the wing. Line them up and drill the holes where ever the turbo wing bolts down. as for the other holes from the factory if you have never did any body work, I would definatley take it to a body shop and they can fill them for you, but it is going to cost, and you will have to get it all repainted. sucks! :thumbdown good luck :thumb:
yeah I think I am going to take it to my buddys uncle's shop for the rest of the body work...cuz Ive come across alot of problems with the blitz front and spaces and the side skirts have trouble fitting...what screws should I use to mount the turbo spoiler?
If you could find some of the factory bolts off of a turbo model that would be the best, if not ask the body shop you are going to.
