Heater Control Assembly
Pop the bezel off, unscrew the panel, unplug the switch, and pop the switch out. it should be held in by a couple tabs.
Ah, ok now i found the tab you need to press in... Thanks Defiant and Locke... BY THE WAY... that tiny little stock dash light took me almost 20 minutes to get out!
