headlight replacement on 90-91?
philipkrotch
Banned Member
904
Feb 9, 2004
butler, Pennsylvania
how do u replace headlights in the 90-91 years with the flip up's? i never did it before. also, has anyone used sylvania cool blue headlights? im thinking about getting them, but i dont want a blue xenon look, i want like a bright white. thanks
Ok I have done this thousands of times, so I can answer your Question. Pop the lights up and get a phillups head screw driver , pliers, and I think an 8mm open end wrench. Now unscrew all the phillups screws around the blk shroud. Thne take of the lid with the wrench, they have a phillups head in them but i assure you it will strip if it hassn't been worked on in a while. Then unscrew the 2 long silver screws that adjust the anglement on the side of the bulb. It will now be attached be a spring, pull it out with the pliers and unplug it. Done. As for the blue bulbs, I have them and are doing the 92-94 conversion, there just not bright enough. Don't get me wrong i love the look of the 90-91 fronts, just doing somthin different.
Josh :dsm: :talon: :laser:
