caliboy23
- 97
- 1
- Nov 8, 2002
I'm doing a budget build up on my 1G cylinder head. I'm ordering the DKS 3 cams with springs and retainers from FFWD Connection. The stock valves will more than likely be reused. The head has already been blasted and inspected and is good to go.
My budget does not allow for porting so I was wondering just how much HP I'll actually be losing by going this route. I am however getting a valve job done. And I'm very capable of gasket matching the head myself, as well as polishing the exhaust ports and combustion chambers.
I have spoken to lots of people reguarding this issue and most people say that a head that gets good machine work can flow 20% more air. With me getting the valve job, my own gasket matching, and my own polishing of the chambers and exhaust ports, I should be ok.
The car will have a SBR G60 turbo and will reuse the stock intake manifold after it gets cleaned up as well. Also the car will have a direct port nitrous kit jetted for a 100 shot. What do you guys think?
... start with a 50 shot and go from there my friend, 100 is alot of nitrous
