Having problems with MBC Install ( long )
Trizon
86
Mar 1, 2004
Panorama city, California
Well, I just recently made my MBC, and am currently trying to install it. I know it should be simple, but the previous owner had an EBC hooked up to it, then the mechanic who installed my motor changed a few hoses around.. Ive scrolled back and seen little things drawn up which tell me this
T into BOV line, run line to Intake Manifold, bottom of tee to in of MBC, bottom of MBC to outer wastegate right?
Heres the problem, I see a nipple on the left side of the Intake Manifold, but its hooked up to something that looks similar to the wastegate solonoid? (if it is the wg, why is it mounted in the back of the bay, is this possible?) -- My boost gauge is teed into there then it seems as if the 2 hoses loop, ill take pictures and post if possible.
But my main question would be, should I remove whatever is hooked up to the intake manifold currently, and run a hose from the end of the BOV tee, then just Tee into that with the boost gauge? -- Anyone have pictures of their intake manifold that current has an MBC hooked up? And what lines should I plug up? Turbo housing, and wastegate solonoid? Anyone happen to have specific pictures? Ive checked the Vfaq install, and checked a few off of google searches, problem is none really show the intake manifold, and since ive had preexisting mods when I bought the car, its hard to work backwards.. On top of that I believe the mechanic swapped the hosing.. its weird none the less. Help is much appreciated :D
dont use the bov line, i tried that and it dint work.........i used the inter cooler line and the bcs lwastegate line, noo spike!
