Greddy profec B spec II problems
Turbo Monk3y
571
7
Oct 14, 2002
Orlando, Florida
Well i did a boost leak test with my key turned to accesory so that i could see my boost on the Profec b. I was trying to get to 25psi or so but everytime i got around 19psi the Greddy solenoid in my engine bay would click a bunch of times and bleed off air so i couldnt go higher than 19psi for my boost leak test... Also when im driving around i have my boost set to 22-23 psi and when it spools up to 19psi it will make that fluttering sound for a second and then it will eventually rise up to 22 or so... Has anyone else had this problem?? My current settings are;
GAIN 8%
Set gain 23.5
set 58%
warning 24.5
warning L 22
I also have the plastic cap removed on the Solenoid..
:confused:
Return that Profec B II and get your money back. Get the Profec B Type-s. RRE doesn't recommend the Profec B II, due to the fact that the unit has so many problems. I got my Profec B Type-S and I have no problems at all. Sometimes old school is better than new school :thumb:
If you read more on the forums about the profec B spec II, you'll see what I'm talking about.
Hope this helps...
