Got a problem, NEED HELP!
slinarez25
104
Sep 15, 2009
Citrus Heights, California
Was there any difference at all in 6 bolt crankshafts? Like auto vs manual.
Because i swapped an engine from a manual car into my auto car and now my tranny wont bolt up right.
There is a little nub that sticks out of the back of the torque converter that goes into the end of the crankshaft, and that nub is a little skinnier and longer than the hole in the crankshaft so it wont go on flush.
But on my other 6 bolt crank it fit like a glove. The hole is just as skinny and deep as the torque converter nub.
So the hole on the new 6 bolt crank is a little wider and more shallow than the old crank, but its still a 6 bolt so i dont know how it could be different!
Im confused! Please help.
P.s. Im POSITIVE the torque converter is all the way in the tranny.
The automatic cranks have a spacer pressed into the back of them for the torque converter. You need to swap that to the new crank.
Then it should bolt up flush? Becuase i physically measured that hole in the old crankshaft (like end of crank to bottom of hole) and it was mathematically deeper than the new one. Would just a spacer fix that?
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
