gear oil
Its up to each individual owner, and there's 10 trillion opinions on this, but the manual states
"MOPAR Hypoid Gear Oil/API classification GL4 or higher, SAE 75W-85W"
The typical go-to fluid is Redline MT-L or MT-90, or a mix of the two. Or if you're rich, go for the mitsu diaqueen, which is supposedly the best fluid for the manual trans.
This is in a 420A transmission in a 2g FWD correct? If so, that takes a special fluid which was known as MS9417 fluid, or NVT350. I don't think it is made anymore so the go-to fluid is ATF+4 fluid. And yes that IS ATF fluid. ;)
