2G Fuel Rail to AFPR Line Size?
jawar666
103
Jun 5, 2007
Costa Rica, Central America
I'm about to install a new Walbro 255LPH High Pressure pump on my car...
SO, Following the recommendations on this forum, I will also install an Aeromotive AFPR with gauge... I will keep my OEM fuel rail...
My question is the following:
The size (I mean thickness) of the SS line I will use from the Fuel Rail to the AFPR, does it matter?
I'm asking because a friend of mine says that if the line is too thin, the pressure in the fuel rail will rise and the AFPR gauge would be lying... for me that's not true, But I want to ask the experts!
I believe -6 AN is pretty much the standard size used. At least that's what comes with the kits that I've seen. I don't see any reason why you can't go bigger with the right fittings. But going smaller than stock will raise fuel pressure independent of the AFPR. So your friend is correct.
The word to describe the size of the hose is diameter, not thickness.
