Fog lights
gabriel_dsm
73
Mar 27, 2014
bakersfield, California
okay i own a 95 eclipse gs i plan on doing a complete swap to a 97-99 now i have oem fogs on my 2ga bumper as of now my question is when i switch the bumpers and install the 2gb fog lights. Can i use the same wiring i have or do i have to switch it all out basically just mount the fogs and plug in my old wire connection to the new fogs and hopefully it works. Can it be done or do i have to switch all of it
as long as the 2gb fogs are oem and not some aftermarket types you are good. same plug style.
If you can use a multimeter to see which lines are your 12v and ground then you can just cut the wires on the fog lights and use your existing plug in, or you can go to yard and find a set of pigtails for fogs that match you lights and cut em off and rewire matching colors?
