FMIC questions
snipe99999
301
May 13, 2002
My mods are in my profile please look there. I just wanted to know if you guys think that I would get a lot more HP if I got a FMIC? I got dyno tuned with the current mods list on pump gas and got 242.1 at the wheels. Also some basic questions are
1. Will the HP increase without turning up the PSI (I am running 17 now)
2. How much HP can I expect after the FMIC (it will be getting dyno tuned on pump gas) (242.1 before the FMIC)
3. Will it be safe for me to turn up the PSI
4. How much boost is safe with my set up.
Let me know what you guys think.
Thanks,
Ian
i didn't look at your mod list, but i can tell you that you will increase your power even if you stay at the same psi. Because it'll be colder and denser air entering the engine which is a big plus.
Ya you could go to a fmic if you have enough cash to get one. Or it depends how far you are going ot go with your setup. ARe u going to eventually upgrade to something like a 20g or fifty trim or bigger? If you arnt you could possibly just get a side mount that replaces the stock one. I know adfx makes a nice sidemount ic.
Pipe kit $200 (look around)
FMIC $400 search spearco FMIC on ebay, those things are beautiful
Boost depends on gas, mods, tuning, etc. Keep turning the boost up until you see knock, then turn it down a lil more :)
  • Wanted 6 bolt NT water pipe
    • chrisman287
