Fixed a rip in the rubber rain gutter
I had water coming in beside the rear passenger seat. There is a rubber rain gutter that runs from behind the convertible top along both sides. It drains just behind the doors. The passenger side rubber gutter was ripped. I removed the back seat, unbolted the seatbelts, and removed the side panels for access. I removed the top supports to allow more wiggle room. Then I used flex seal tape to make the gutter hold water. Then I restapled the top and reconnected the supports. There is an S hook that holds the bottom of the gutter down through the hole which allows the water to drain to the outside.
  • Wanted 6 bolt NT water pipe
    • chrisman287
