FIC 650 Injector Install Problem..
FWD98GST
149
Apr 6, 2003
San Diego, California
I just installed a set of FIC 650's and I have a problem where when I go WOT, the car buckles around 4.5K.. I believe I have adequate enough of fuel going to the injectors with a HP Walbro 190 (rewired). Do I need a FPR and a 255 fuel pump just to run these 650's? I have no boost leak what so ever.. Prior to installing 650, my car was running fine with the 550's, but when the moment I installed the 650's, I have the buckling at WOT around 4.5K.. Any inputs??
Thanks..
yah i did.. i went -31% across the board in "HI".. but i was reading other post about FIC injectors.. The seals on the injectors maybe be bad?? Maybe I should try to switch out the seals and use seals that I was using on my 550's...
Do you have a logger?
What is the o2 sensor voltage?
What is the timing doing when it bucks?
I sounds like you are hitting a mini fuel cut. I have ran into this. I leaned out the car some more in the mid range and took care of the problem.
Just make sure you are watching your gauges and monitoring everything.
Yah.. I fixed the problem.. It was the FIC lower O-ring seals that were bad.. I put on some new, tougher, O-ring seals and everything runs better and stronger.. Thanks for all your help..
Canadian. Please Check PM...
Thanks...
