Evo 1 ECU in 91?
But its a 96..so that would make it a 2nd...if you know what i mean
Would i have to change pins or anything? If i install 510 injectors car should be fine right?
No, the Evo I is a 1992. Injector size is different as well as a few other things. Not sure if it will work to be honest; I know the ECU code is very different between the Evo I and 1G/2G.
