1G Error codes 12, 13, 14, 25?
805eclipse
159
Jul 16, 2003
Newbury Park, California
ok my car is running like crap and i hooked up my datalogger and its throwing these codes... 12 Air flow Sensor, 13 Air Temp Sensor, 25 Barometric Pressure sensor, and 14 TPS. i knew that the tps was out of calibration and i need to adjust it but all the other error codes does that all have to do with the MAF? does this mean its bad and if the maf sensor is bad would that make my car run like crap?
I had all the same codes in my 1G as well. After replacing the MAF my car is still like crap. Has anyone had these happen to them? Currently it is throwing out the Barametric pressure sensor code and before it was the Intake Air Temp sensor. Is the Barametric sensor located in the MAF also?
Thanks!!
:dsm:
